hi
would you please tell me what are zeta, salt and temp criterion for blowing up ?
and usually what parameters should be checked for finding blow up reason?
cheers
redhat
criterion
Re: criterion
You can look in diag.F to see the blow-up criteria. One is a velocity larger than max_speed, the other is a density larger than max_rho. Both max_speed and max_rho are set in mod_scalars.F. The logic used to find the maximum velocity can be copied to zeta, T and S, but it has not been done in the trunk code.
If you are running my ice branch, there's a check in ice_frazil.F that will trip over odd values of T like -300. I have also made diag.F more verbose so that I get a report like (just this morning, in fact):
239325 33208 21:30:00 3.608264E-03 1.703917E+04 1.703917E+04 3.289577E+16
(543,0266,50) 6.686609E-04 1.023531E-01 9.435409E+00 7.383824E+01
DIAG speed trouble 73.83824443803645
DIAG speed ijk 88.75332729210966 404 71 25
