coupling with COAWST
m567tej
Location: Iranian National Institute for Oceanography and Atmospheric Sciences
#1 Unread post by m567tej »
Dear all
I configured a coupled model (roms+swan) for different grids. it seems that evrything is good, it works and make results but after 45 day it seems that go to a kind of stop, not message not blow up and not do anything. I have just the results for first 45 day :!: .
after running each model separtely, roms model works completely for 1 year requested time simulation but swan stop without warning after 45 days. according to point table results, both of RTpeak & TPsmoo are equal to 25 sec. the swan .in file are included with
PROJECT 'Caspian Sea' '0001'
'SWAN ONLY'
MODE NONSTATIONARY TWODIMENSIONAL
SET 0 90 0.1 200 1 9.81 1012 INRHOG 1 NAUTICAL 4 0.8 4 4
COORDINATES SPHERICAL QC
CGRID CURVilinear 105 192 EXC 9.999000e+003 CIRCLE 36 0.04 1.0 20
READGRID COORDINATES 1 '/opt/models/Projects/Caspian112/grids/caspian_swan_coord.grd' 4 0 0 FREE
INPGRID BOTTOM CURVILINEAR 46.1 36.1 105 192 EXC 9.999000e+003
READINP BOTTOM 1 '/opt/models/Projects/Caspian112/grids/caspian_swan_bathy.bot' 4 0 FREE
INPGRID WInd CURVILINEAR 46.1 36.1 105 192 &
NONSTATionary 20120101.000000 3.0 HR 20121231.180000
READinp WInd 1 '/opt/models/Projects/Caspian112/forcing_swan/swan_force.wnd' 1 FREe
BOUNd SHAPespec JONswap 3.3 PEAK POWer
INITial DEFault
GEN3 KOMen 2.35e-5 AGROW 0.0015
WCAPping 4.0
QUADrupl 2
BREaking CONSTANT 1.0 0.73
FRICtion COLLINS 0.025
TRIAd 0 0.05 2.5 0.2 0.01
LIMiter 10.0 1.0
OFF FSHift
OFF BNDCHK
$ ********************************* OUTPUT *****************************************
POINts 'point1' 49.43333 37.50180
TABLE 'point1' HEADER 'Projects/Caspian112/Swanonly/C1_output/point1.table' &
TIME DEPTH XP YP HSIGN DIR RTP TPS TM01 TM02 DSPR WIND OUTPUT 20120101 1 HR
SPECOUT 'point1' SPEC2D 'Projects/Caspian112/Swanonly/C1_output/point1.spc2d' OUTPUT 20120101 1 HR
POINts 'point2' 49.76667 37.69996
TABLE 'point2' HEADER 'Projects/Caspian112/Swanonly/C1_output/point2.table' &
SPECOUT 'point2' SPEC2D 'Projects/Caspian112/Swanonly/C1_output/point2.spc2d' OUTPUT 20120101 1 HR
TEST 1 0
PROP BSBT
COMPute NONSTat 20120101.000000 30 MIN 20121231.180000
STOP
so, how can I find resource of problem? comments?
Re: coupling with COAWST
this looks like an issue with your swan setup. Did it give any Err* files? Is there any information in the PRINT files? Does your wind forcing go for the whole year? did you run out of hard disk space?
-john
m567tej
#3 Unread post by m567tej »
dear john, thanks for your reply
you right. the problem caused by wind forcing, I recreate the wind file and use idla=1 according to my instruction. swan fully working.
cheeers
