Error while compiling with gfortran COAWST
lfelipem
#1 Unread post by lfelipem »
I'm compiling with gfortran COAWST model and the following error occurs :
/ usr/lib64/mpi/gcc/openmpi/bin/mpif90 - frepack - arrays - O3 - ffast -math -I/home/lfelipem/COAWST/Lib/MCT/include -I/home/lfelipem/COAWST/Lib/MCT / include . / Build / esmf_roms.o . / Build / get_sparse_matrix.o . / Build / master.o . / Build / mct_coupler_params.o . / Build / mct_coupler_utils.o . / Build / mod_coupler_iounits.o . / Build / mod_coupler_kinds . the . / Build / ocean_control.o . / Build / ocean_coupler.o . / Build / propagator.o . / Build / read_couplepar.o . / Build / roms_export.o . / Build / roms_import.o it coawstM . / Build / libNLM.a . / Build / libNLM_bio.a . / Build / libNLM_sed.a . / Build / libNLM_wec.a . / Build / libANA.a . / Build / libUTIL.a . / Build / libMODS.a . / Build / libSWAN . -L/usr/lib - to - lnetcdff lnetcdf -L/home/lfelipem/COAWST/Lib/MCT/lib - LMCT - lmpeu -L/home/lfelipem/COAWST/Lib/MCT/lib - LMCT - lmpeu WRF / main / module_wrf_top.o WRF / main / libwrflib.a WRF/external/fftpack/fftpack5/libfftpack.a WRF/external/io_grib1/libio_grib1.a WRF / external / io_grib_share / libio_grib_share.a WRF / external / io_int / libwrfio_int.a WRF/external/esmf_time_f90/libesmf_time.a WRF / external / RSL_LITE / librsl_lite.a WRF / frame / module_internal_header_util.o WRF / frame / pack_utils.o WRF / external / io_netcdf / libwrfio_nf.a
. / Build / master.o : In function ` main__ ' :
master.f90 : ( . text +0 X4C1 ) : undefined reference to ` module_wrf_top_wrf_init_ '
master.f90 : ( . text +0 x4c8 ) : undefined reference to ` module_wrf_top_wrf_run_ '
master.f90 : ( . text +0 x4cf ) : undefined reference to ` module_wrf_top_wrf_finalize_ '
collect2 : ld returned 1 exit status
make: *** [ coawstM ] Error 1
Can anyone tell me why this problem?
Someone already got the same error ?
Re: Error while compiling with gfortran COAWST
yes i have a correction for this. i will send you an email about it.
It has to deal with the way the module names and subroutines are put together.
-john
perezdbea
#3 Unread post by perezdbea »
cd /home/beatriz/SOFTWARE/COAWST/V3.1_082014/Build; /usr/bin/mpif90 -c -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -fconvert=big-endian -frecord-marker=4 -I/usr/local/include -I/usr/include -I../WRF/main -I../WRF/external/esmf_time_f90 -I../WRF/frame -I../WRF/share mct_coupler_params.f90
mct_coupler_params.f90:2.32:
USE mct_wrf_coupler_params
1
Fatal Error: Can't open module file 'mct_wrf_coupler_params.mod' for reading at (1): No such file or directory
Can anyone tell me why this problem, is depend on the compiler? (i read that is better to compile mct library with intel or pgi compilers..)
Thank
