Nope. The time variable (
sms_time,
srf_time,
shf_time, or
swf_time) in the NetCDF file created by the script
d_ecmwf2roms.m is in days
The number of time records in a NetCDF file is independent of the units of the time coordinate. In ROMS, the default is to provide the units for the forcing fields as
days since a reference time.
You are confusing the units given by the ERA file:
dimensions:
time = 2920 ;
variables:
int time(time) ;
time:units = "hours since 1900-01-01 00:00:0.0" ;
time:long_name = "time" ;
In a leap year, you will have 2928 time records. Otherwise, you will get 2920 time records.
You cannot use directly the file generated by ERA into ROMS
We need to process the ERA fields to get the correct force for ROMS. Just check the time variable for the ROMS forcing NetCDF files. For example, we can have:
double sms_time(sms_time) ;
sms_time:long_name = "surface momentum stress time" ;
sms_time:units = "days since 2000-01-01 00:00:00" ;
sms_time:calendar = "gregorian" ;
data:
sms_time = 0.0625, 0.1875, 0.3125, 0.4375, 0.5625, 0.6875, 0.8125, 0.9375,
1.0625, 1.1875, 1.3125, 1.4375, 1.5625, 1.6875, 1.8125, 1.9375, 2.0625,
2.1875, 2.3125, 2.4375, 2.5625, 2.6875, 2.8125, 2.9375, 3.0625, 3.1875,
3.3125, 3.4375, 3.5625, 3.6875, 3.8125, 3.9375, 4.0625, 4.1875, 4.3125,
4.4375, 4.5625, 4.6875, 4.8125, 4.9375, 5.0625, 5.1875, 5.3125, 5.4375,
