hi,
when i run roms with my own application, it blows up.i get the error message from the log file,
(File: shiyf_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = -9.98224053E+03 Max = 6.25174815E+04)
- salinity
(Min = -9.99900000E+03 Max = 4.08229370E+01)
i set missing value -9999.in land, From above,the error may be result from my input file, but when i check my ini file use matlab
clear all;close all
filename = 'E:\ROMS\predata\shiyf_ini.nc';
grd = 'E:\ROMS\predata\seagrid.nc';
temp = ncread(filename,'temp');
lon = ncread(grd,'lon_rho');
lat = ncread(grd,'lat_rho');
mask = ncread(grd,'mask_rho');
[i_rho j_rho]=size(mask);
for i =1:i_rho
for j=1:j_rho
if mask(i,j)==1
if min(temp(i,j,:)) <-10.||max(temp(i,j,:)) > 50.
disp(i)
disp(j)
disp(temp(i,j,:))
break
end
end
end
end
temp values in ocean are all normal,the SSS's condition in frc file is the same.
I am very confused why roms reading is not correct?Can you give me some advice,
the log file
Wednesday - December 25, 2013 - 2:36:13 AM
SHIYF
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /lustre/inspur/mpi/openmpi-intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script : ocean_shiyf.in
SVN Revision : Unversioned directory
Local Root : /lustre/home/shiyongfangWKJ/roms/trunk
Header Dir : /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Header file : shiyf.h
Analytical Dir: /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Resolution, Grid 01: 0119x0449x016, Parallel Nodes: 40, Tiling: 004x010
207360 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
17280 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
17280 nHIS Number of timesteps between the writing fields
into history file.
207360 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
17280 nAVG Number of timesteps between the writing of
207360 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
30.000 Tcline S-coordinate surface/bottom layer width (m) used
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
Prefix for History Files: ocean_his
Prefix for Averages Files: ocean_avg
Input Grid File: shiyf_grd.nc
Input Nonlinear Initial File: shiyf_ini.nc
Input Forcing File 01: shiyf_frc.nc
Input Boundary File: shiyf_bry.nc
Tile partition information for Grid 01: 0119x0449x0016 tiling: 004x010
tile Istr Iend Jstr Jend Npts
0 1 30 1 45 21600
1 31 60 1 45 21600
2 61 90 1 45 21600
3 91 119 1 45 20880
4 1 30 46 90 21600
5 31 60 46 90 21600
6 61 90 46 90 21600
7 91 119 46 90 20880
8 1 30 91 135 21600
9 31 60 91 135 21600
10 61 90 91 135 21600
11 91 119 91 135 20880
12 1 30 136 180 21600
13 31 60 136 180 21600
14 61 90 136 180 21600
15 91 119 136 180 20880
16 1 30 181 225 21600
17 31 60 181 225 21600
18 61 90 181 225 21600
19 91 119 181 225 20880
20 1 30 226 270 21600
21 31 60 226 270 21600
22 61 90 226 270 21600
23 91 119 226 270 20880
24 1 30 271 315 21600
25 31 60 271 315 21600
26 61 90 271 315 21600
27 91 119 271 315 20880
28 1 30 316 360 21600
29 31 60 316 360 21600
30 61 90 316 360 21600
31 91 119 316 360 20880
32 1 30 361 405 21600
33 31 60 361 405 21600
34 61 90 361 405 21600
35 91 119 361 405 20880
36 1 30 406 449 21120
37 31 60 406 449 21120
38 61 90 406 449 21120
39 91 119 406 449 20416
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 30.50 0.50 45.50 RHO-points
1 30.50 60.50 0.50 45.50 RHO-points
2 60.50 90.50 0.50 45.50 RHO-points
3 90.50 119.50 0.50 45.50 RHO-points
4 0.50 30.50 45.50 90.50 RHO-points
5 30.50 60.50 45.50 90.50 RHO-points
6 60.50 90.50 45.50 90.50 RHO-points
7 90.50 119.50 45.50 90.50 RHO-points
8 0.50 30.50 90.50 135.50 RHO-points
9 30.50 60.50 90.50 135.50 RHO-points
10 60.50 90.50 90.50 135.50 RHO-points
11 90.50 119.50 90.50 135.50 RHO-points
12 0.50 30.50 135.50 180.50 RHO-points
13 30.50 60.50 135.50 180.50 RHO-points
14 60.50 90.50 135.50 180.50 RHO-points
15 90.50 119.50 135.50 180.50 RHO-points
16 0.50 30.50 180.50 225.50 RHO-points
17 30.50 60.50 180.50 225.50 RHO-points
18 60.50 90.50 180.50 225.50 RHO-points
19 90.50 119.50 180.50 225.50 RHO-points
20 0.50 30.50 225.50 270.50 RHO-points
21 30.50 60.50 225.50 270.50 RHO-points
22 60.50 90.50 225.50 270.50 RHO-points
23 90.50 119.50 225.50 270.50 RHO-points
24 0.50 30.50 270.50 315.50 RHO-points
25 30.50 60.50 270.50 315.50 RHO-points
26 60.50 90.50 270.50 315.50 RHO-points
27 90.50 119.50 270.50 315.50 RHO-points
28 0.50 30.50 315.50 360.50 RHO-points
29 30.50 60.50 315.50 360.50 RHO-points
30 60.50 90.50 315.50 360.50 RHO-points
31 90.50 119.50 315.50 360.50 RHO-points
32 0.50 30.50 360.50 405.50 RHO-points
33 30.50 60.50 360.50 405.50 RHO-points
34 60.50 90.50 360.50 405.50 RHO-points
35 90.50 119.50 360.50 405.50 RHO-points
36 0.50 30.50 405.50 449.50 RHO-points
37 30.50 60.50 405.50 449.50 RHO-points
38 60.50 90.50 405.50 449.50 RHO-points
39 90.50 119.50 405.50 449.50 RHO-points
0 1.00 30.50 0.50 45.50 U-points
1 30.50 60.50 0.50 45.50 U-points
2 60.50 90.50 0.50 45.50 U-points
3 90.50 119.00 0.50 45.50 U-points
4 1.00 30.50 45.50 90.50 U-points
5 30.50 60.50 45.50 90.50 U-points
6 60.50 90.50 45.50 90.50 U-points
7 90.50 119.00 45.50 90.50 U-points
8 1.00 30.50 90.50 135.50 U-points
9 30.50 60.50 90.50 135.50 U-points
10 60.50 90.50 90.50 135.50 U-points
11 90.50 119.00 90.50 135.50 U-points
12 1.00 30.50 135.50 180.50 U-points
13 30.50 60.50 135.50 180.50 U-points
14 60.50 90.50 135.50 180.50 U-points
15 90.50 119.00 135.50 180.50 U-points
16 1.00 30.50 180.50 225.50 U-points
17 30.50 60.50 180.50 225.50 U-points
18 60.50 90.50 180.50 225.50 U-points
19 90.50 119.00 180.50 225.50 U-points
20 1.00 30.50 225.50 270.50 U-points
21 30.50 60.50 225.50 270.50 U-points
22 60.50 90.50 225.50 270.50 U-points
23 90.50 119.00 225.50 270.50 U-points
24 1.00 30.50 270.50 315.50 U-points
25 30.50 60.50 270.50 315.50 U-points
26 60.50 90.50 270.50 315.50 U-points
27 90.50 119.00 270.50 315.50 U-points
28 1.00 30.50 315.50 360.50 U-points
29 30.50 60.50 315.50 360.50 U-points
30 60.50 90.50 315.50 360.50 U-points
31 90.50 119.00 315.50 360.50 U-points
32 1.00 30.50 360.50 405.50 U-points
33 30.50 60.50 360.50 405.50 U-points
34 60.50 90.50 360.50 405.50 U-points
35 90.50 119.00 360.50 405.50 U-points
36 1.00 30.50 405.50 449.50 U-points
37 30.50 60.50 405.50 449.50 U-points
38 60.50 90.50 405.50 449.50 U-points
39 90.50 119.00 405.50 449.50 U-points
0 0.50 30.50 1.00 45.50 V-points
1 30.50 60.50 1.00 45.50 V-points
2 60.50 90.50 1.00 45.50 V-points
3 90.50 119.50 1.00 45.50 V-points
4 0.50 30.50 45.50 90.50 V-points
5 30.50 60.50 45.50 90.50 V-points
6 60.50 90.50 45.50 90.50 V-points
7 90.50 119.50 45.50 90.50 V-points
8 0.50 30.50 90.50 135.50 V-points
9 30.50 60.50 90.50 135.50 V-points
10 60.50 90.50 90.50 135.50 V-points
11 90.50 119.50 90.50 135.50 V-points
12 0.50 30.50 135.50 180.50 V-points
13 30.50 60.50 135.50 180.50 V-points
14 60.50 90.50 135.50 180.50 V-points
15 90.50 119.50 135.50 180.50 V-points
16 0.50 30.50 180.50 225.50 V-points
17 30.50 60.50 180.50 225.50 V-points
18 60.50 90.50 180.50 225.50 V-points
19 90.50 119.50 180.50 225.50 V-points
20 0.50 30.50 225.50 270.50 V-points
21 30.50 60.50 225.50 270.50 V-points
22 60.50 90.50 225.50 270.50 V-points
23 90.50 119.50 225.50 270.50 V-points
24 0.50 30.50 270.50 315.50 V-points
25 30.50 60.50 270.50 315.50 V-points
26 60.50 90.50 270.50 315.50 V-points
27 90.50 119.50 270.50 315.50 V-points
28 0.50 30.50 315.50 360.50 V-points
29 30.50 60.50 315.50 360.50 V-points
30 60.50 90.50 315.50 360.50 V-points
31 90.50 119.50 315.50 360.50 V-points
32 0.50 30.50 360.50 405.50 V-points
33 30.50 60.50 360.50 405.50 V-points
34 60.50 90.50 360.50 405.50 V-points
35 90.50 119.50 360.50 405.50 V-points
36 0.50 30.50 405.50 449.00 V-points
37 30.50 60.50 405.50 449.00 V-points
38 60.50 90.50 405.50 449.00 V-points
39 90.50 119.50 405.50 449.00 V-points
HaloSizeI(1) = 84
HaloSizeJ(1) = 114
TileSide(1) = 51
TileSize(1) = 1836
zeta 1 Closed Clamped Clamped Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
tke 1 Closed Clamped Clamped Closed
SHIYF SHIYF
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 4 (pid= 32061) is active.
Node # 20 (pid= 28884) is active.
Node # 10 (pid= 31893) is active.
Node # 17 (pid= 31900) is active.
Node # 12 (pid= 31895) is active.
Node # 36 (pid= 1919) is active.
Node # 15 (pid= 31898) is active.
Node # 28 (pid= 28892) is active.
Node # 14 (pid= 31897) is active.
Node # 1 (pid= 32058) is active.
Node # 9 (pid= 32066) is active.
Node # 33 (pid= 1916) is active.
Node # 25 (pid= 28889) is active.
Node # 7 (pid= 32064) is active.
Node # 23 (pid= 28887) is active.
Node # 31 (pid= 1914) is active.
Node # 16 (pid= 31899) is active.
Node # 39 (pid= 1922) is active.
Node # 0 (pid= 32057) is active.
Node # 8 (pid= 32065) is active.
Node # 24 (pid= 28888) is active.
Node # 32 (pid= 1915) is active.
Node # 11 (pid= 31894) is active.
Node # 2 (pid= 32059) is active.
Node # 26 (pid= 28890) is active.
Node # 18 (pid= 31901) is active.
Node # 34 (pid= 1917) is active.
Node # 3 (pid= 32060) is active.
Node # 27 (pid= 28891) is active.
Node # 19 (pid= 31902) is active.
Node # 35 (pid= 1918) is active.
Node # 21 (pid= 28885) is active.
Node # 5 (pid= 32062) is active.
Node # 13 (pid= 31896) is active.
Node # 37 (pid= 1920) is active.
Node # 29 (pid= 28893) is active.
Node # 6 (pid= 32063) is active.
Node # 22 (pid= 28886) is active.
Node # 30 (pid= 1913) is active.
Node # 38 (pid= 1921) is active.
Vertical S-coordinate System:
15 -0.0625000 -0.0048948 -2.482 -1.011 -15.660 -28.640
14 -0.1250000 -0.0119914 -5.346 -2.055 -37.530 -69.324
13 -0.1875000 -0.0230908 -8.907 -3.159 -70.690 -131.905
12 -0.2500000 -0.0409944 -13.651 -4.365 -123.039 -231.706
11 -0.3125000 -0.0696342 -20.262 -5.732 -205.668 -390.235
10 -0.3750000 -0.1133185 -29.490 -7.325 -330.726 -631.060
9 -0.4375000 -0.1742175 -41.712 -9.176 -504.336 -966.052
8 -0.5000000 -0.2489214 -56.334 -11.234 -716.880 -1376.559
7 -0.5625000 -0.3284417 -71.794 -13.364 -943.008 -1813.413
6 -0.6250000 -0.4042644 -86.611 -15.439 -1158.706 -2230.040
5 -0.6875000 -0.4744488 -100.448 -17.429 -1358.504 -2615.825
4 -0.7500000 -0.5437741 -114.135 -19.407 -1555.879 -2996.911
3 -0.8125000 -0.6205544 -129.118 -21.496 -1774.279 -3418.777
2 -0.8750000 -0.7145184 -147.090 -23.843 -2041.142 -3934.639
1 -0.9375000 -0.8366254 -169.957 -26.612 -2387.377 -4604.450
0 -1.0000000 -1.0000000 -200.000 -30.000 -2850.000 -5500.000
Time Splitting Weights: ndtfast = 15 nfast = 22
1-0.0006740978872509 0.0666666666666667-0.0006740978872509 0.0666666666666667
2-0.0001913161153518 0.0667116065258167-0.0008654140026027 0.1333782731924834
3 0.0014472038369421 0.0667243609335069 0.0005817898343395 0.2001026341259903
4 0.0042370228855824 0.0666278806777107 0.0048188127199218 0.2667305148037010
5 0.0081665994120431 0.0663454124853385 0.0129854121319649 0.3330759272890396
6 0.0132119623624627 0.0658009725245357 0.0261973744944276 0.3988768998135752
7 0.0193298623751124 0.0649201750337048 0.0455272368695400 0.4637970748472801
8 0.0264494009361902 0.0636315175420307 0.0719766378057303 0.5274285923893107
9 0.0344621375639418 0.0618682241462847 0.1064387753696720 0.5892968165355954
10 0.0432106750211074 0.0595707483086885 0.1496494503907794 0.6488675648442840
11 0.0524757225556949 0.0566900366406147 0.2021251729464743 0.7055576014848987
12 0.0619616371700794 0.0531916551369017 0.2640868101165537 0.7587492566218004
13 0.0712804429184289 0.0490608793255631 0.3353672530349826 0.8078101359473635
14 0.0799343282324558 0.0443088497976678 0.4153015812674384 0.8521189857450313
15 0.0872966212754959 0.0389798945821708 0.5025982025429343 0.8910988803272021
16 0.0925912433249121 0.0331601198304711 0.5951894458678464 0.9242590001576731
17 0.0948706401828253 0.0269873702754769 0.6900600860506717 0.9512463704331501
18 0.0929921916151718 0.0206626609299552 0.7830522776658435 0.9719090313631054
19 0.0855930988190858 0.0144631814889438 0.8686453764849293 0.9863722128520491
20 0.0710637499186094 0.0087569749010047 0.9397091264035388 0.9951291877530538
21 0.0475195634887281 0.0040193915730974 0.9872286898922669 0.9991485793261512
22 0.0127713101077333 0.0008514206738489 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 15 22 nfast/ndtfast = 1.46667
1.000000000000 1.070450639131 0.535225319565 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.09467
Minimum X-grid spacing, DXmin = 8.48739060E+00 km
Maximum X-grid spacing, DXmax = 9.59010345E+01 km
Minimum Y-grid spacing, DYmin = 1.97654987E+01 km
Maximum Y-grid spacing, DYmax = 5.56286561E+01 km
Minimum Z-grid spacing, DZmin = 2.48171081E+00 m
Maximum Z-grid spacing, DZmax = 8.95550429E+02 m
Minimum barotropic Courant Number = 9.69255846E-03
Maximum barotropic Courant Number = 9.00101619E-02
Maximum Coriolis Courant Number = 1.92843807E-02
Horizontal mixing scaled by grid size, GRDMAX = 7.28116721E+01 km
- free-surface
- salinity
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0012, Index=1, File: shiyf_frc.nc)
(Min = -9.75512195E+00 Max = 8.27846076E-05)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -9.75512195E+00 Max = 1.66505575E-04)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Min = -2.44796034E-03 Max = 6.54721022E-05)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -2.44796034E-03 Max = 2.58579529E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -1.15729126E-03 Max = 1.15583962E-07)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = -9.99900000E+03 Max = 4.07532845E+01)
(Rec=0012, Index=2, File: shiyf_bry.nc)
(Min = -5.81862376E-01 Max = 9.57945365E+00)
(Min = -3.65501400E-01 Max = 8.04470641E+00)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.43556882E+02 Max = 1.40019754E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = 0.00000000E+00 Max = 1.89365791E+02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -8.99202521E-03 Max = 3.99919066E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -8.63434183E-02 Max = 3.60160155E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.53312044E+03 Max = 3.30222533E-02)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = 0.00000000E+00 Max = 2.53142997E+03)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -5.44804139E-01 Max = 2.41975658E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.88590554E+00 Max = 1.13105720E+00)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = -2.72054750E+00 Max = 1.48424599E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 8.51362923E+00 Max = 3.63578905E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 1.50453202E+00 Max = 2.74800147E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.33199475E+01 Max = 3.52573975E+01)
Maximum grid stiffness ratios: rx0 = 9.273286E-01 (Beckmann and Haidvogel)
rx1 = 1.409255E+01 (Haney)
Initial basin volumes: TotVolume = 3.9063693677E+17 m3
MinVolume = 2.3066237529E+09 m3
MaxVolume = 4.0996942351E+12 m3
Max/Min = 1.7773571567E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00207360)
(Rec=0001, Index=2, File: shiyf_frc.nc)
(Min = -9.75512195E+00 Max = 9.38875355E-05)
(Min = -9.75512195E+00 Max = 1.62762607E-04)
(Min = -2.44796034E-03 Max = 6.92072962E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -2.44796034E-03 Max = 3.07865833E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = -1.15729126E-03 Max = 1.14237994E-07)
(Min = -9.99900000E+03 Max = 4.00087700E+01)
(Rec=0001, Index=1, File: shiyf_bry.nc)
(Min = -3.34679358E-01 Max = 9.57787214E+00)
(Min = -3.37361403E-01 Max = 8.05706182E+00)
(Min = -2.43560545E+02 Max = 1.32895002E-03)
(Min = -7.88433526E-03 Max = 3.57221571E-03)
(Min = -6.98625588E-02 Max = 3.03533820E-02)
(Min = -2.53313185E+03 Max = 1.76022060E-02)
(Min = -4.77691997E-01 Max = 2.16141044E-01)
(Min = -1.72189022E+00 Max = 9.60177938E-01)
(Min = -2.58442841E+00 Max = 1.06106594E+01)
(Min = 9.07068764E+00 Max = 3.63554746E+01)
(Min = 1.50453202E+00 Max = 2.71757121E+01)
(Min = 3.35264814E+01 Max = 3.51822212E+01)
0 0 00:00:00 4.312250E+00 2.254635E+04 2.255066E+04 4.003951E+17
(119,427,10) 7.132390E+00 0.000000E+00 0.000000E+00 1.791191E+03
Elapsed CPU time (seconds):
Node # 1 CPU: 1.232
Node # 4 CPU: 1.234
Node # 6 CPU: 1.237
Node # 3 CPU: 1.230
Node # 5 CPU: 1.232
Node # 7 CPU: 1.226
Node # 8 CPU: 1.225
Node # 2 CPU: 1.231
Node # 9 CPU: 1.225
Node # 0 CPU: 0.542
Analytical header files used:
ROMS/Functionals/ana_btflux.h
Node # 25 CPU: 1.236
Node # 29 CPU: 1.202
Node # 37 CPU: 1.196
Node # 23 CPU: 1.227
Node # 30 CPU: 1.213
Node # 38 CPU: 1.197
Node # 11 CPU: 1.247
Node # 28 CPU: 1.222
Node # 16 CPU: 1.201
Node # 24 CPU: 1.216
Node # 17 CPU: 1.179
Node # 20 CPU: 1.209
Node # 21 CPU: 1.195
Node # 27 CPU: 1.230
Node # 26 CPU: 1.235
Node # 19 CPU: 1.221
Node # 22 CPU: 1.195
Node # 15 CPU: 1.164
Node # 33 CPU: 1.209
Node # 12 CPU: 1.237
Node # 39 CPU: 1.220
Node # 14 CPU: 1.193
Node # 32 CPU: 1.211
Node # 10 CPU: 1.238
Node # 34 CPU: 1.209
Node # 13 CPU: 1.192
Node # 35 CPU: 1.218
Node # 18 CPU: 1.206
Node # 36 CPU: 1.230
Node # 31 CPU: 1.194
Re: ROMS/TOMS - Blows up ................ exit_flag: 1
What did you call the missing value attribute for your T and S in the initial file? Can we see the "ncdump -h" of it? I know ROMS understands the _FillValue attribute and you can check the reading routines (nf_fread3d.F say) for the attributes ROMS will check.
