problem when first running upwelling test
Hi
I'm trying to run upwelling test and I get some troubles, like:
rm -f -r core *.ipo /Projects/upwelling/Build /home/fei/make_macros.mk
In file included from Compilers/make_macros.h:16:0:
Compilers/../ROMS/Include/cppdefs.h:625:22: fatal error: /Projects/upwelling/upwelling.h: No such file or directory
compilation terminated.
makefile:238: INCLUDING FILE /home/fei/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cp -f /home/fei/netcdf/include/netcdf.mod /Projects/upwelling/Build
cp -f /home/fei/netcdf/include/typesizes.mod /Projects/upwelling/Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=/Projects/upwelling/Build -DROMS_HEADER="upwelling.h" -I ROMS/Include -I /Projects/upwelling -I ROMS/Nonlinear -I ROMS/Nonlinear/Biology -I ROMS/Nonlinear/Sediment -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /Projects/upwelling -I Master -I Compilers --silent --moddir /Projects/upwelling/Build ROMS/Nonlinear/bbl.F ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/bc_bry2d.F ROMS/Nonlinear/bc_bry3d.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/conv_3d.F ROMS/Nonlinear/conv_bry2d.F ROMS/Nonlinear/conv_bry3d.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/frc_adjust.F ROMS/Nonlinear/get_data.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/hmixing.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/initial.F ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/main3d.F ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/nesting.F ROMS/Nonlinear/obc_adjust.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/omega.F ROMS/Nonlinear/output.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/set_data.F ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/step3d_uv.F ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/v2dbc_im.F ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/vwalk_floats.F ROMS/Nonlinear/wetdry.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/zetabc.F ROMS/Nonlinear/Biology/biology.F ROMS/Nonlinear/Biology/biology_floats.F ROMS/Nonlinear/Sediment/sed_bed.F ROMS/Nonlinear/Sediment/sed_bedload.F ROMS/Nonlinear/Sediment/sed_fluxes.F ROMS/Nonlinear/Sediment/sediment.F ROMS/Nonlinear/Sediment/sed_settling.F ROMS/Nonlinear/Sediment/sed_surface.F ROMS/Functionals/analytical.F ROMS/Utility/abort.F ROMS/Utility/array_modes.F ROMS/Utility/back_cost.F ROMS/Utility/cgradient.F ROMS/Utility/checkadj.F ROMS/Utility/checkdefs.F ROMS/Utility/checkerror.F ROMS/Utility/checkvars.F ROMS/Utility/close_io.F ROMS/Utility/congrad.F ROMS/Utility/convolve.F ROMS/Utility/cost_grad.F ROMS/Utility/def_avg.F ROMS/Utility/def_diags.F ROMS/Utility/def_dim.F ROMS/Utility/def_error.F ROMS/Utility/def_floats.F ROMS/Utility/def_gst.F ROMS/Utility/def_hessian.F ROMS/Utility/def_his.F ROMS/Utility/def_impulse.F ROMS/Utility/def_info.F ROMS/Utility/def_ini.F ROMS/Utility/def_lanczos.F ROMS/Utility/def_mod.F ROMS/Utility/def_norm.F ROMS/Utility/def_rst.F ROMS/Utility/def_station.F ROMS/Utility/def_tides.F ROMS/Utility/def_var.F ROMS/Utility/distribute.F ROMS/Utility/dotproduct.F ROMS/Utility/erf.F ROMS/Utility/extract_obs.F ROMS/Utility/extract_sta.F ROMS/Utility/frc_weak.F ROMS/Utility/gasdev.F ROMS/Utility/get_2dfld.F ROMS/Utility/get_2dfldr.F ROMS/Utility/get_3dfld.F ROMS/Utility/get_3dfldr.F ROMS/Utility/get_bounds.F ROMS/Utility/get_cycle.F ROMS/Utility/get_date.F ROMS/Utility/get_grid.F ROMS/Utility/get_gst.F ROMS/Utility/get_ngfld.F ROMS/Utility/get_ngfldr.F ROMS/Utility/get_state.F ROMS/Utility/get_varcoords.F ROMS/Utility/grid_coords.F ROMS/Utility/ini_adjust.F ROMS/Utility/ini_hmixcoef.F ROMS/Utility/ini_lanczos.F ROMS/Utility/inner2state.F ROMS/Utility/inp_par.F ROMS/Utility/inquire.F ROMS/Utility/interpolate.F ROMS/Utility/lbc.F ROMS/Utility/lubksb.F ROMS/Utility/ludcmp.F ROMS/Utility/metrics.F ROMS/Utility/mp_exchange.F ROMS/Utility/mp_routines.F ROMS/Utility/nf_fread2d_bry.F ROMS/Utility/nf_fread2d.F ROMS/Utility/nf_fread3d_bry.F ROMS/Utility/nf_fread3d.F ROMS/Utility/nf_fread4d.F ROMS/Utility/nf_fwrite2d_bry.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite3d_bry.F ROMS/Utility/nf_fwrite3d.F ROMS/Utility/nf_fwrite4d.F ROMS/Utility/normalization.F ROMS/Utility/nrutil.F ROMS/Utility/ntimestep.F ROMS/Utility/obs_cost.F ROMS/Utility/obs_depth.F ROMS/Utility/obs_initial.F ROMS/Utility/obs_read.F ROMS/Utility/obs_write.F ROMS/Utility/packing.F ROMS/Utility/posterior.F ROMS/Utility/posterior_var.F ROMS/Utility/ran1.F ROMS/Utility/random_ic.F ROMS/Utility/ran_state.F ROMS/Utility/read_asspar.F ROMS/Utility/read_biopar.F ROMS/Utility/read_couplepar.F ROMS/Utility/read_fltbiopar.F ROMS/Utility/read_fltpar.F ROMS/Utility/read_phypar.F ROMS/Utility/read_sedpar.F ROMS/Utility/read_stapar.F ROMS/Utility/regrid.F ROMS/Utility/rep_matrix.F ROMS/Utility/set_2dfld.F ROMS/Utility/set_2dfldr.F ROMS/Utility/set_3dfld.F ROMS/Utility/set_3dfldr.F ROMS/Utility/set_contact.F ROMS/Utility/set_diags.F ROMS/Utility/set_masks.F ROMS/Utility/set_ngfld.F ROMS/Utility/set_ngfldr.F ROMS/Utility/set_scoord.F ROMS/Utility/set_weights.F ROMS/Utility/shapiro.F ROMS/Utility/sqlq.F ROMS/Utility/state_addition.F ROMS/Utility/state_copy.F ROMS/Utility/state_dotprod.F ROMS/Utility/state_initialize.F ROMS/Utility/state_product.F ROMS/Utility/state_scale.F ROMS/Utility/stats_modobs.F ROMS/Utility/stiffness.F ROMS/Utility/strings.F ROMS/Utility/sum_grad.F ROMS/Utility/timers.F ROMS/Utility/uv_rotate.F ROMS/Utility/vorticity.F ROMS/Utility/white_noise.F ROMS/Utility/wpoints.F ROMS/Utility/wrt_avg.F ROMS/Utility/wrt_diags.F ROMS/Utility/wrt_error.F ROMS/Utility/wrt_floats.F ROMS/Utility/wrt_gst.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_his.F ROMS/Utility/wrt_impulse.F ROMS/Utility/wrt_info.F ROMS/Utility/wrt_ini.F ROMS/Utility/wrt_rst.F ROMS/Utility/wrt_station.F ROMS/Utility/wrt_tides.F ROMS/Utility/zeta_balance.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_average.F ROMS/Modules/mod_bbl.F ROMS/Modules/mod_behavior.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_coupler.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_diags.F ROMS/Modules/mod_eclight.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_kinds.F ROMS/Modules/mod_mixing.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_param.F ROMS/Modules/mod_scalars.F ROMS/Modules/mod_sedbed.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_tides.F Master/esmf_roms.F Master/master.F Master/ocean_control.F Master/ocean_coupler.F Master/propagator.F Master/roms_export.F Master/roms_import.F > /Projects/upwelling/Build/MakeDepend
cp -p /home/fei/make_macros.mk /Projects/upwelling/Build
makefile:234: INCLUDING FILE /Projects/upwelling/Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/Projects/upwelling"' ROMS/Utility/abort.F > /Projects/upwelling/Build/abort.f90
In file included from ROMS/Utility/abort.F:2:0:
ROMS/Include/cppdefs.h:625:0: fatal error: /Projects/upwelling/upwelling.h: No such file or directory
make: *** [/Projects/upwelling/Build/abort.f90] Error 1
Who know the solution. Thanks in advance!
Re: problem when first running upwelling test
Are you using build.bash or the raw makefile? Where are you compiling from relative you your source code? There is something wrong with your MY_HEADER_DIR value. If using build.bash, this comes from MY_ROOT_DIR and MY_PROJECT_DIR. How do you have them set?Compilers/../ROMS/Include/cppdefs.h:625:22: fatal error: /Projects/upwelling/upwelling.h: No such file or directory
Thanks kate for your answer
I'm using build.bash and the raw makefile. My source code is at /home/fei/roms/trunk.
MY_ROOT_DIR and MY_PROJECT_DIR as follows:
Thanks again
export MY_ROOT_DIR=/home/fei/
export MY_PROJECT_DIR=${MY_PROJECT_DIR}/Projects/upwelling
There seems to be wrong in make_macros.h. Should I configure it?In file included from Compilers/make_macros.h:16:0:
Thanks again
This last line is adding "/Projects/upwelling" to the previous definition of MY_PROJECT_DIR. It seems that it's previous definition was a null string. Did you mean:shifei wrote:I'm using build.bash and the raw makefile. My source code is at /home/fei/roms/trunk.
MY_ROOT_DIR and MY_PROJECT_DIR as follows:Code: Select all
export MY_ROOT_DIR=/home/fei/ export MY_PROJECT_DIR=${MY_PROJECT_DIR}/Projects/upwelling
export MY_PROJECT_DIR=${MY_ROOT_DIR}/Projects/upwelling
export MY_ROOT_DIR=/home/fei/roms/trunk
Hi kate:
I'm sorry. I'm so careless. I modify the MY_PROJECT_DIR:
After I run again, I got the problem as follow:
What's the meaning of the last line
rm -f -r core *.ipo /home/fei//Projects/upwelling/Build /home/fei/make_macros.mk
cp -f /home/fei/netcdf/include/netcdf.mod /home/fei//Projects/upwelling/Build
cp -f /home/fei/netcdf/include/typesizes.mod /home/fei//Projects/upwelling/Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=/home/fei//Projects/upwelling/Build -DROMS_HEADER="upwelling.h" -I ROMS/Include -I /home/fei//Projects/upwelling -I ROMS/Nonlinear -I ROMS/Nonlinear/Biology -I ROMS/Nonlinear/Sediment -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /home/fei//Projects/upwelling -I Master -I Compilers --silent --moddir /home/fei//Projects/upwelling/Build ROMS/Nonlinear/bbl.F ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/bc_bry2d.F ROMS/Nonlinear/bc_bry3d.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/conv_3d.F ROMS/Nonlinear/conv_bry2d.F ROMS/Nonlinear/conv_bry3d.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/frc_adjust.F ROMS/Nonlinear/get_data.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/hmixing.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/initial.F ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/main3d.F ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/nesting.F ROMS/Nonlinear/obc_adjust.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/omega.F ROMS/Nonlinear/output.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/set_data.F ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/step3d_uv.F ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/v2dbc_im.F ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/vwalk_floats.F ROMS/Nonlinear/wetdry.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/zetabc.F ROMS/Nonlinear/Biology/biology.F ROMS/Nonlinear/Biology/biology_floats.F ROMS/Nonlinear/Sediment/sed_bed.F ROMS/Nonlinear/Sediment/sed_bedload.F ROMS/Nonlinear/Sediment/sed_fluxes.F ROMS/Nonlinear/Sediment/sediment.F ROMS/Nonlinear/Sediment/sed_settling.F ROMS/Nonlinear/Sediment/sed_surface.F ROMS/Functionals/analytical.F ROMS/Utility/abort.F ROMS/Utility/array_modes.F ROMS/Utility/back_cost.F ROMS/Utility/cgradient.F ROMS/Utility/checkadj.F ROMS/Utility/checkdefs.F ROMS/Utility/checkerror.F ROMS/Utility/checkvars.F ROMS/Utility/close_io.F ROMS/Utility/congrad.F ROMS/Utility/convolve.F ROMS/Utility/cost_grad.F ROMS/Utility/def_avg.F ROMS/Utility/def_diags.F ROMS/Utility/def_dim.F ROMS/Utility/def_error.F ROMS/Utility/def_floats.F ROMS/Utility/def_gst.F ROMS/Utility/def_hessian.F ROMS/Utility/def_his.F ROMS/Utility/def_impulse.F ROMS/Utility/def_info.F ROMS/Utility/def_ini.F ROMS/Utility/def_lanczos.F ROMS/Utility/def_mod.F ROMS/Utility/def_norm.F ROMS/Utility/def_rst.F ROMS/Utility/def_station.F ROMS/Utility/def_tides.F ROMS/Utility/def_var.F ROMS/Utility/distribute.F ROMS/Utility/dotproduct.F ROMS/Utility/erf.F ROMS/Utility/extract_obs.F ROMS/Utility/extract_sta.F ROMS/Utility/frc_weak.F ROMS/Utility/gasdev.F ROMS/Utility/get_2dfld.F ROMS/Utility/get_2dfldr.F ROMS/Utility/get_3dfld.F ROMS/Utility/get_3dfldr.F ROMS/Utility/get_bounds.F ROMS/Utility/get_cycle.F ROMS/Utility/get_date.F ROMS/Utility/get_grid.F ROMS/Utility/get_gst.F ROMS/Utility/get_ngfld.F ROMS/Utility/get_ngfldr.F ROMS/Utility/get_state.F ROMS/Utility/get_varcoords.F ROMS/Utility/grid_coords.F ROMS/Utility/ini_adjust.F ROMS/Utility/ini_hmixcoef.F ROMS/Utility/ini_lanczos.F ROMS/Utility/inner2state.F ROMS/Utility/inp_par.F ROMS/Utility/inquire.F ROMS/Utility/interpolate.F ROMS/Utility/lbc.F ROMS/Utility/lubksb.F ROMS/Utility/ludcmp.F ROMS/Utility/metrics.F ROMS/Utility/mp_exchange.F ROMS/Utility/mp_routines.F ROMS/Utility/nf_fread2d_bry.F ROMS/Utility/nf_fread2d.F ROMS/Utility/nf_fread3d_bry.F ROMS/Utility/nf_fread3d.F ROMS/Utility/nf_fread4d.F ROMS/Utility/nf_fwrite2d_bry.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite3d_bry.F ROMS/Utility/nf_fwrite3d.F ROMS/Utility/nf_fwrite4d.F ROMS/Utility/normalization.F ROMS/Utility/nrutil.F ROMS/Utility/ntimestep.F ROMS/Utility/obs_cost.F ROMS/Utility/obs_depth.F ROMS/Utility/obs_initial.F ROMS/Utility/obs_read.F ROMS/Utility/obs_write.F ROMS/Utility/packing.F ROMS/Utility/posterior.F ROMS/Utility/posterior_var.F ROMS/Utility/ran1.F ROMS/Utility/random_ic.F ROMS/Utility/ran_state.F ROMS/Utility/read_asspar.F ROMS/Utility/read_biopar.F ROMS/Utility/read_couplepar.F ROMS/Utility/read_fltbiopar.F ROMS/Utility/read_fltpar.F ROMS/Utility/read_phypar.F ROMS/Utility/read_sedpar.F ROMS/Utility/read_stapar.F ROMS/Utility/regrid.F ROMS/Utility/rep_matrix.F ROMS/Utility/set_2dfld.F ROMS/Utility/set_2dfldr.F ROMS/Utility/set_3dfld.F ROMS/Utility/set_3dfldr.F ROMS/Utility/set_contact.F ROMS/Utility/set_diags.F ROMS/Utility/set_masks.F ROMS/Utility/set_ngfld.F ROMS/Utility/set_ngfldr.F ROMS/Utility/set_scoord.F ROMS/Utility/set_weights.F ROMS/Utility/shapiro.F ROMS/Utility/sqlq.F ROMS/Utility/state_addition.F ROMS/Utility/state_copy.F ROMS/Utility/state_dotprod.F ROMS/Utility/state_initialize.F ROMS/Utility/state_product.F ROMS/Utility/state_scale.F ROMS/Utility/stats_modobs.F ROMS/Utility/stiffness.F ROMS/Utility/strings.F ROMS/Utility/sum_grad.F ROMS/Utility/timers.F ROMS/Utility/uv_rotate.F ROMS/Utility/vorticity.F ROMS/Utility/white_noise.F ROMS/Utility/wpoints.F ROMS/Utility/wrt_avg.F ROMS/Utility/wrt_diags.F ROMS/Utility/wrt_error.F ROMS/Utility/wrt_floats.F ROMS/Utility/wrt_gst.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_his.F ROMS/Utility/wrt_impulse.F ROMS/Utility/wrt_info.F ROMS/Utility/wrt_ini.F ROMS/Utility/wrt_rst.F ROMS/Utility/wrt_station.F ROMS/Utility/wrt_tides.F ROMS/Utility/zeta_balance.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_average.F ROMS/Modules/mod_bbl.F ROMS/Modules/mod_behavior.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_coupler.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_diags.F ROMS/Modules/mod_eclight.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_kinds.F ROMS/Modules/mod_mixing.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_param.F ROMS/Modules/mod_scalars.F ROMS/Modules/mod_sedbed.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_tides.F Master/esmf_roms.F Master/master.F Master/ocean_control.F Master/ocean_coupler.F Master/propagator.F Master/roms_export.F Master/roms_import.F > /home/fei//Projects/upwelling/Build/MakeDepend
cp -p /home/fei/make_macros.mk /home/fei//Projects/upwelling/Build
makefile:234: INCLUDING FILE /home/fei//Projects/upwelling/Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Utility/abort.F > /home/fei//Projects/upwelling/Build/abort.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/abort.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' Master/ocean_control.F > /home/fei//Projects/upwelling/Build/ocean_control.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/ocean_control.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Functionals/analytical.F > /home/fei//Projects/upwelling/Build/analytical.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/analytical.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Utility/distribute.F > /home/fei//Projects/upwelling/Build/distribute.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/distribute.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Modules/mod_iounits.F > /home/fei//Projects/upwelling/Build/mod_iounits.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/mod_iounits.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Modules/mod_param.F > /home/fei//Projects/upwelling/Build/mod_param.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/mod_param.f90
/usr/bin/cpp -P -traditional -DMPI -DLINUX -DX86_64 -DIFORT -D'ROOT_DIR="/home/fei/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/fei//Projects/upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/fei//Projects/upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="687M"' -IROMS/Include -I/home/fei//Projects/upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/fei//Projects/upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/fei//Projects/upwelling"' ROMS/Modules/mod_kinds.F > /home/fei//Projects/upwelling/Build/mod_kinds.f90
ROMS/Bin/cpp_clean /home/fei//Projects/upwelling/Build/mod_kinds.f90
cd /home/fei//Projects/upwelling/Build; -c -heap-arrays -fp-model precise -g -check bounds -traceback -check uninit -warn interfaces,nouncalled -gen-interfaces -free mod_kinds.f90
/bin/sh: 1: -c: not found
make: *** [/home/fei//Projects/upwelling/Build/mod_kinds.o] Error 127
This one has made it into the FAQ:
The command:
FC := $(shell which ${FC})
in the Compilers/xxx-xxx.mk file has failed to find the compiler you specified, setting FC to the null string. You need to find out which compiler you were asking it to look for and to make sure it is in your path. If the flag USE_MPIF90 is set, it will be looking for "mpif90". What do you get from the command "which mpif90"? If you are trying for a serial run first, what does "which gfortran" give you?
cd Build; -c -O3 mod_kinds.f90
/bin/sh: -c: not found
Hi kate,
I got nothing from the command 'which mpif90 which gfortran'
I use ifort compiler. After I put 'which ifort',I got '/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/ifort'.
I tried to set FC :=$(/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/ifort).
The problem is still unsolved. What should I configure FC?
Assuming you are on linux, you want to set FORT to ifort, which will include the Compilers/Linux-ifort.mk file. There, it sets FC to ifort, then:
Then later, it does:
So, how are you setting USE_MPI and USE_MPIF90? Where did you set FC to its full path?
ifdef USE_MPI
CPPFLAGS += -DMPI
ifdef USE_MPIF90
FC := mpif90
else
LIBS += -lfmpi-pgi -lmpi-pgi
endif
endif
Hi kate,
I am on linux, I want to set FORT to ifort.
In Linux-ifort.mk file, I didn't set USE_MPI and USE_MPIF90.
I have read the FAQ, but I don't how to set them.
how can I set the USE_MPI, USE_MPIF90 and the FC to its full path.
What happens if you set FC to the full path, then comment out this line:
Kate, I'm sorry for my not reply, because I was on a business trip several days ago.
In the following code
If I set FC
I will get
ifdef USE_MPI
CPPFLAGS += -DMPI
ifdef USE_MPIF90
FC := /opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/ifort
LD := $(FC)
else
If I set FC
FC := /home/fei/local/openmpi/bin/mpif90
cd /home/fei//Projects/upwelling/Build; ifort -c -heap-arrays -fp-model precise -openmp -fpp -g -check bounds -traceback -check uninit -warn interfaces,nouncalled -gen-interfaces -free mod_kinds.f90
/bin/sh: 1: ifort: not found
Did you try what I suggest in my previous post? Don't mess with the MPI section of you aren't trying for MPI.
So you're getting nothing from "which ifort" from inside the makefile, but you are getting the correct path from outside. Here is where you need a crash course on Unix shells and environment variables, specifically the $PATH environment variable. Simpler to try my previous post.
HI it seems that i do have the same problem, but i try as much as i can to fix it but still the same problem
So i m using cygwin on my windows, my header are as follow:
export ROMS_APPLICATION=UPWELLING
# Set a local environmental variable to define the path to the directories
# where all this project's files are kept.
export MY_ROOT_DIR=/home/roms
# The path to the user's local current ROMS source code.
# If using svn locally, this would be the user's Working Copy Path (WCPATH).
# Note that one advantage of maintaining your source code locally with svn
# is that when working simultaneously on multiple machines (e.g. a local
# workstation, a local cluster and a remote supercomputer) you can checkout
# the latest release and always get an up-to-date customized source on each
# machine. This script is designed to more easily allow for differing paths
# to the code and inputs on differing machines.
#export MY_ROMS_SRC=${MY_ROOT_DIR}/branches/arango
export MY_ROMS_SRC=${MY_ROOT_DIR}/trunk
and when i compile it returns :
$ ./build.bash
rm -f -r core *.ipo /home/roms/Projects/Upwelling/Build /home/make_macros.mk
Compilers/../ROMS/Include/cppdefs.h:632:22: fatal error: /home/roms/Projects/Upwelling/upwelling.h: No such file or directory
# include ROMS_HEADER
makefile:238: INCLUDING FILE /home/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cp -f /usr/local/include/netcdf.mod /home/roms/Projects/Upwelling/Build
cp -f /usr/local/include/typesizes.mod /home/roms/Projects/Upwelling/Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=/home/roms/Projects/Upwelling/Build -DROMS_HEADER="upwelling.h" -I ROMS/Include -I /home/roms/Projects/Upwelling -I ROMS/Nonlinear -I ROMS/Nonlinear/Biology -I ROMS/Nonlinear/Sediment -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /home/roms/Projects/Upwelling -I Master -I Compilers --silent --moddir /home/roms/Projects/Upwelling/Build ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/vwalk_floats.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/wetdry.F ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/obc_adjust.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/set_data.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/nesting.F ROMS/Nonlinear/get_data.F ROMS/Nonlinear/initial.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/step3d_uv.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/omega.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/output.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/hmixing.F ROMS/Nonlinear/main3d.F ROMS/Nonlinear/conv_bry2d.F ROMS/Nonlinear/conv_bry3d.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/zetabc.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/bbl.F ROMS/Nonlinear/bc_bry3d.F ROMS/Nonlinear/frc_adjust.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/v2dbc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/bc_bry2d.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/conv_3d.F ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/Biology/biology_floats.F ROMS/Nonlinear/Biology/biology.F ROMS/Nonlinear/Sediment/sed_bed.F ROMS/Nonlinear/Sediment/sed_settling.F ROMS/Nonlinear/Sediment/sed_surface.F ROMS/Nonlinear/Sediment/sed_fluxes.F ROMS/Nonlinear/Sediment/sed_bedload.F ROMS/Nonlinear/Sediment/sediment.F ROMS/Functionals/analytical.F ROMS/Utility/def_diags.F ROMS/Utility/read_fltbiopar.F ROMS/Utility/get_2dfld.F ROMS/Utility/convolve.F ROMS/Utility/nf_fread3d.F ROMS/Utility/wrt_his.F ROMS/Utility/state_addition.F ROMS/Utility/nrutil.F ROMS/Utility/state_initialize.F ROMS/Utility/read_asspar.F ROMS/Utility/def_hessian.F ROMS/Utility/get_3dfld.F ROMS/Utility/inner2state.F ROMS/Utility/read_phypar.F ROMS/Utility/set_contact.F ROMS/Utility/ludcmp.F ROMS/Utility/ini_lanczos.F ROMS/Utility/abort.F ROMS/Utility/def_ini.F ROMS/Utility/obs_read.F ROMS/Utility/read_biopar.F ROMS/Utility/back_cost.F ROMS/Utility/checkadj.F ROMS/Utility/stats_modobs.F ROMS/Utility/get_cycle.F ROMS/Utility/nf_fread4d.F ROMS/Utility/wrt_diags.F ROMS/Utility/nf_fread3d_bry.F ROMS/Utility/lubksb.F ROMS/Utility/wrt_floats.F ROMS/Utility/extract_sta.F ROMS/Utility/wrt_info.F ROMS/Utility/state_scale.F ROMS/Utility/def_lanczos.F ROMS/Utility/regrid.F ROMS/Utility/nf_fwrite3d.F ROMS/Utility/packing.F ROMS/Utility/def_gst.F ROMS/Utility/def_mod.F ROMS/Utility/nf_fwrite3d_bry.F ROMS/Utility/read_sedpar.F ROMS/Utility/read_fltpar.F ROMS/Utility/get_bounds.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_gst.F ROMS/Utility/congrad.F ROMS/Utility/checkdefs.F ROMS/Utility/wpoints.F ROMS/Utility/sqlq.F ROMS/Utility/def_tides.F ROMS/Utility/zeta_balance.F ROMS/Utility/set_3dfld.F ROMS/Utility/normalization.F ROMS/Utility/posterior.F ROMS/Utility/set_2dfldr.F ROMS/Utility/obs_cost.F ROMS/Utility/checkerror.F ROMS/Utility/obs_depth.F ROMS/Utility/nf_fread2d.F ROMS/Utility/set_2dfld.F ROMS/Utility/nf_fread2d_bry.F ROMS/Utility/wrt_station.F ROMS/Utility/get_3dfldr.F ROMS/Utility/distribute.F ROMS/Utility/state_dotprod.F ROMS/Utility/get_ngfld.F ROMS/Utility/rep_matrix.F ROMS/Utility/frc_weak.F ROMS/Utility/vorticity.F ROMS/Utility/cost_grad.F ROMS/Utility/def_error.F ROMS/Utility/nf_fwrite4d.F ROMS/Utility/mp_exchange.F ROMS/Utility/def_avg.F ROMS/Utility/set_ngfldr.F ROMS/Utility/check_multifile.F ROMS/Utility/timers.F ROMS/Utility/ini_hmixcoef.F ROMS/Utility/gasdev.F ROMS/Utility/ran1.F ROMS/Utility/array_modes.F ROMS/Utility/interpolate.F ROMS/Utility/stiffness.F ROMS/Utility/get_state.F ROMS/Utility/dotproduct.F ROMS/Utility/ntimestep.F ROMS/Utility/shapiro.F ROMS/Utility/close_io.F ROMS/Utility/wrt_ini.F ROMS/Utility/extract_obs.F ROMS/Utility/get_grid.F ROMS/Utility/wrt_tides.F ROMS/Utility/get_2dfldr.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite2d_bry.F ROMS/Utility/set_weights.F ROMS/Utility/ini_adjust.F ROMS/Utility/get_ngfldr.F ROMS/Utility/checkvars.F ROMS/Utility/set_masks.F ROMS/Utility/get_varcoords.F ROMS/Utility/def_impulse.F ROMS/Utility/def_dim.F ROMS/Utility/read_stapar.F ROMS/Utility/def_var.F ROMS/Utility/inquire.F ROMS/Utility/wrt_error.F ROMS/Utility/get_date.F ROMS/Utility/wrt_avg.F ROMS/Utility/posterior_var.F ROMS/Utility/def_rst.F ROMS/Utility/white_noise.F ROMS/Utility/def_norm.F ROMS/Utility/mp_routines.F ROMS/Utility/state_copy.F ROMS/Utility/def_info.F ROMS/Utility/lbc.F ROMS/Utility/def_his.F ROMS/Utility/random_ic.F ROMS/Utility/def_floats.F ROMS/Utility/state_product.F ROMS/Utility/cgradient.F ROMS/Utility/erf.F ROMS/Utility/get_gst.F ROMS/Utility/ran_state.F ROMS/Utility/strings.F ROMS/Utility/set_scoord.F ROMS/Utility/sum_grad.F ROMS/Utility/metrics.F ROMS/Utility/uv_rotate.F ROMS/Utility/read_couplepar.F ROMS/Utility/set_3dfldr.F ROMS/Utility/wrt_impulse.F ROMS/Utility/set_diags.F ROMS/Utility/obs_initial.F ROMS/Utility/def_station.F ROMS/Utility/set_ngfld.F ROMS/Utility/inp_par.F ROMS/Utility/grid_coords.F ROMS/Utility/wrt_rst.F ROMS/Utility/obs_write.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_coupler.F ROMS/Modules/mod_param.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_diags.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_kinds.F ROMS/Modules/mod_bbl.F ROMS/Modules/mod_behavior.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_average.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_tides.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_eclight.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_scalars.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_sedbed.F ROMS/Modules/mod_mixing.F Master/ocean_control.F Master/esmf_roms.F Master/ocean_coupler.F Master/roms_export.F Master/master.F Master/propagator.F Master/roms_import.F > /home/roms/Projects/Upwelling/Build/MakeDepend
cp -p /home/make_macros.mk /home/roms/Projects/Upwelling/Build
makefile:234: INCLUDING FILE /home/roms/Projects/Upwelling/Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
/usr/bin/cpp -P -traditional -DCYGWIN -DX86_64 -DGFORTRAN -D'ROOT_DIR="/home/roms/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="/home/roms/Projects/Upwelling/upwelling.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/home/roms/Projects/Upwelling"' -D'MY_ANALYTICAL="on"' -D'SVN_REV="718"' -IROMS/Include -I/home/roms/Projects/Upwelling -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/home/roms/Projects/Upwelling -IMaster -ICompilers -D'HEADER_DIR="/home/roms/Projects/Upwelling"' ROMS/Utility/def_diags.F > /home/roms/Projects/Upwelling/Build/def_diags.f90
In file included from ROMS/Utility/def_diags.F:2:0:
ROMS/Include/cppdefs.h:632:0: fatal error: /home/roms/Projects/Upwelling/upwelling.h: No such file or directory
ROMS/Utility/Module.mk:15: recipe for target '/home/roms/Projects/Upwelling/Build/def_diags.f90' failed
make: *** [/home/roms/Projects/Upwelling/Build/def_diags.f90] Error 1
Any idea what is the problem
thank you.
$ ./build.bash
thank you.
The compiler is telling you what the error is. It cannot find the ROMS header file for this application: /Projects/upwelling/upwelling.h. It cannot be more simpler than thatROMS/Include/cppdefs.h:625:0: fatal error: /Projects/upwelling/upwelling.h: No such file or directory
Read the errors that the compiler is giving you...
