Problem with Bulk_flux
bhatt.vihang
#1 Unread post by bhatt.vihang »
I was facing problem with computation of bulk fluxes over land masked region. They were generating NaNs as RH was masked out to be 0. The code
          IF (RH.lt.2.0_r8) THEN                       !RH fraction
               cff=cff*RH                                 !Vapor pres (mb)
               Q(i)=0.62197_r8*(cff/(PairM-0.378_r8*cff)) !Spec hum (kg/kg)
          ELSE          !RH input was actually specific humidity in g/kg
            Q(i)=RH/1000.0_r8                          !Spec Hum (kg/kg)
was modified as
# ifdef MASKING
            if (rmask(i,j).NE.0) then
# ifdef MASKING
            else
               Q(i)=rmask(i,j)
            endif
This has stopped generting NaNs. Hope this helps.
Re: Problem with Bulk_flux
#2 Unread post by arango »
Why are you masking the surface air pressure?
bhatt.vihang
#3 Unread post by bhatt.vihang »
I use Pyroms to generate forcing fields that is automatically masking all fields over the land. I am still looking into how to undo this.
