Blowing up after 9966 timesteps
kee
Location: Nanjing Uni. of Info. Sci. & Tech. (nanjing institute of meterology)
#1 Unread post by kee »
I am very confused that the model blow up at the 9966 timestep. I am sure the CFL creteria is satisfied.
I think that if the DT is not small enough, the model can blow up shortly after the starting. Now it blowup at the 9966th timestep, it is more likely that waves shorter than 4*DX cause the results. But I am not sure.
Similar situations have occured times(like after around 190000 integrations), but I donot know how to deal with the problem.
I wonder that this maybe have something with the APPLICATION.h and Values set in the IN-file.
Both of the files are in the attachment.
Can anyone give some ideas?
Thanks in advance.
out-file.txt
(1.56 MiB) Downloaded 835 times
h-file.txt
(1.75 KiB) Downloaded 810 times
in-file.txt
(102.24 KiB) Downloaded 691 times
Re: Blowing up after 9966 timesteps
We can't tell what the problem is from the setup without running it all over again. Instead, you need to build up tools for looking at the model output and learning to see what makes sense and what doesn't. Did it blow up because of a large velocity or because the tracer fields got weird? Where did it happen? At the surface, bottom or in the middle?
Blowing up at step 9966 could mean you were at the edge of instability and just crossed over or it could be something else entirely.
ptimko
#3 Unread post by ptimko »
You have what would appear to be a baroclinic instability. I would suggest checking you vertical mixing model. I have had problems in the past with ROMS by not specifying a vertical mixing model. The problem was solved by specifying a GLS mixing model in the model options during the build process. It may not be the probelm you have but it might be a starting point to look at...
kee
#4 Unread post by kee »
kate wrote:Did it blow up because of a large velocity or because the tracer fields got weird? Where did it happen? At the surface, bottom or in the middle?
Kate, thanks a lot!
I checked the output and some information is pasted below
   9965    20 18:15:00  1.879129E-02  2.160202E+04  2.160204E+04  1.049255E+16
          (741,047,11)  2.108176E-01  7.250023E-02  5.464230E-01  4.778940E+00
   9966    20 18:18:00  1.882934E-02           NaN           NaN  1.049255E+16
          (741,047,11)  2.095299E-01  7.145118E-02  5.451024E-01  4.739977E+00
It seems like that the break came from POTEN_ENRG and TOTAL_ENRG on the 11th level which is a middle level.
In my configuration the grid is 899*662*20 in Xi, Eta and Vertical respectively.
I donnot know how the POTEN_ENRG and TOTAL_ENRG are caculated in the model, either.
can you give more advice?
kee
#5 Unread post by kee »
ptimko wrote:... The problem was solved by specifying a GLS mixing model in the model options during the build process. It may not be the probelm you have but it might be a starting point to look at...
Hi ptimko,
Thanks for yr kindly reply.
I did specify a GLS mixing model in the APPLICATION.h, like
#define GLS_MIXING
#undef MY25_MIXING
This can also be seen in the logfile
 GLS_MIXING          Generic Length-Scale turbulence closure.
I am wondering if I can modify the values of the mixing parameters a little bigger to prevent instability, but I donot know.
is there any further suggestions?
#6 Unread post by kate »
You can look at diag.F and see how it computes the energies. They are globally integrated quantities, so the location you see listed there doesn't tell you where the NaN is coming from. The location is that of the largest velocity, one that is not alarmingly large. You need to be looking at the 3D fields in say the restart file if it created a record on blowup. I use ncview for a quick and dirty view of what's going on.
#7 Unread post by kate »
kee wrote:I am wondering if I can modify the values of the mixing parameters a little bigger to prevent instability, but I donot know.
GLS has different behaviors depending on the parameters you give it. Some suggestions are in the ocean.in file. I have found some to behave better than others. I am using the K-omega option.
ptimko
#8 Unread post by ptimko »
I'm also using the K-omega option. Not sure what else to suggest right now, if I think I'll let you know.
