hello:
I am trying to simulate tide by 2D-ROMS.
I only retain sustr and sms_time in the frc.nc. At the same time, tide is added to the frc.nc. ANA_INITIAL and ANA_BMFLUX is defined.Compiling is ok, but something is wrong when running .
Can anyone help me?
Output info:
Minimum X-grid spacing, DXmin = 2.75248895E+00 km
Maximum X-grid spacing, DXmax = 3.20812877E+00 km
Minimum Y-grid spacing, DYmin = 2.75409673E+00 km
Maximum Y-grid spacing, DYmax = 3.20766198E+00 km
Minimum barotropic Courant Number = 1.85253133E-01
Maximum barotropic Courant Number = 9.71708342E-01
Maximum Coriolis Courant Number = 5.84041068E-03
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 3.26393686E-05 Max = 6.68537894E+00)
(Min = 2.41898787E-06 Max = 6.28318020E+00)
(Min = 4.97589188E-07 Max = 6.28318253E+00)
(Min = 2.59098604E-06 Max = 6.28318291E+00)
(Min = 1.27754016E-06 Max = 1.42023097E+00)
(Min = -5.23102760E-01 Max = 4.38586697E-01)
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0000012, Index=1, File: barotropic_tide_frc.nc)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
INQUIRE - unable to assign file counter, Fcount = 0
while processing structure:
and variable; zeta_east
call from: inquire.FQUIRE - unable to assign file counter, Fcount = 0
unable to open existing NetCDF file: call from: inquire.
Re: unable to open existing NetCDF file: call from: inquire
It is having trouble with the boundary conditions. You don't say which boundary options you are using. For tides you probably want Chapman/Flather for the barotropic mode. You then might want to do something like ADD_FSOBC and ANA_FSOBC to add the tidal elevation to an analytic zero elevation. You can look at globaldefs.h to see what the logic is asking for to turn off the searching for boundary files.
- Location: National Marine Environmental Forecasting Center
Hi, Kate. Thank you very much!
I took the your suggestion and it did work.I think this is because ROMS will not read LBC values(ubar,vbar,zeta) from *_frc.nc. Either *_bry.nc or ana_fsobc(or ana_m2obc) is needed to ROMS, right? This is also why Lm(or Mn) in the *.in equals Lm(or Mn)-2 in the *_frc.nc made by roms_tools.
