I am trying to use ICESHELF for the model.
But it asks for the zice in grid file. Could someone tell what sizes should zice be? And which file requires specifying zice?
Thanks very much!
Fan
zice in grid file for ICESHELF
Re: zice in grid file for ICESHELF
zice is on the rho grid. It is the thickness of ice above the ocean at each gridpoint. Since ice shelves can be hundreds of meters thick, the pressure from that ice is important to take into consideration.
As for which files want to know about it, a simple grep command from the top of the ROMS tree should smoke that out:get_grid.F has the code for reading the grid file.
grep -i zice */*/*
Thanks Kate!
BTW, do you have any suggestions on where to obtain the iceshelf thickness data?
I learned that some use this dataset:
http://nsidc.org/api/metadata?id=gla12
Fan
Fan
kate wrote:zice is on the rho grid. It is the thickness of ice above the ocean at each gridpoint. Since ice shelves can be hundreds of meters thick, the pressure from that ice is important to take into consideration.
As for which files want to know about it, a simple grep command from the top of the ROMS tree should smoke that out:get_grid.F has the code for reading the grid file.Code: Select all
grep -i zice */*/*
As a consistent data set for bedrock and ice shelf topography as well grounding line positions you might consider the following data set
Timmermann, R, et al. (2010), "A consistent dataset of Antarctic ice sheet topography, cavity geometry, and global bathymetry", Earth Syst. Sci. Data, 2, 261-273, 2010. doi:10.5194/essd-2-261-2010 , hdl:10013/epic.36409
To go to the data repository directly follow
http://doi.pangaea.de/10.1594/PANGAEA.741917
Good luck
Good luck
Thanks very much!
Fan
Fan
crode1968 wrote:As a consistent data set for bedrock and ice shelf topography as well grounding line positions you might consider the following data set
Good luck
