Cross Shelf Model
LRasmuson
Cross Shelf Model
#1 Unread post by LRasmuson »
Hi All,
I am working on developing an idealized cross shelf model of upwelling. I have read articles where other researchers have been able to develop similar models but I am unsure how people are dealing with generating a grid and inputting the dimensions into a *.in file. Are people generating grids with >1 cell in both the I and J directions and then focusing their development and analysis of a specific slice in the J direction or if I enter a J direction as 1 will the model be able to compile and run in parallel? If I missed a previous post about this topic I apologize but I was unable to find anything in my searching.
Leif
Re: Cross Shelf Model
The default setup for ROMS is just that - a periodic channel with an idealized upwelling problem. It goes by the application name UPWELLING. It is periodic in the i direction and Lm has to be at least 3, I believe. There are walls north and south. The grid is all set up internal to ROMS, as described in the ROMS manual.
LRasmuson
#3 Unread post by LRasmuson »
Thank you very much for the help this is exactly what I needed. I have been looking at the upwelling test case but wasn't sure how to model just cross-shelf since the test case dimensions are Lm=41 and Mm=80.
Leif
m.hadfield
Reduce Lm in the input file to a smaller number. As Kate said, the minimum is probably 3; whatever, 1 is not permitted. Whatever value of Lm you choose, the UPWELLING simulation is homogeneous in the xi direction, so you can do your analyses on any slice
