Dear everyone:
I try to run the inlet test case ,I know that it is a case of coupling between roms and swan.
I have succeed compiling it . My platform is unbuntu 12.10 ,mpif90 gfortran mpich2 mct
When I want to run it ,I get an error ! Please help me ! Thank you !
next is the information on the screen
chenzhen@chenzhen-ThinkPad-T410:~/Projects/inlet_test$ mpiexec -np 4 ./oceanM coupling_inlet_test.in
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 001
Waves Model MPI nodes: 002 - 003
Sunday - January 13, 2013 - 9:36:39 AM
SWAN is preparing computation ...
Inlet Test Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/home/chenzhen/ROMS/MCT/mct -I/home/chenzhen/ROMS/MCT/mpeu -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-
Input Script : ocean_inlet_test.in
SVN Revision : 643M
Local Root : /home/chenzhen/roms
Header Dir : /home/chenzhen/Projects/inlet_test
Header file : inlet_test.h
Analytical Dir: /home/chenzhen/Projects/inlet_test
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 2, Tiling: 002x001
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
Physical parameters File: ocean_inlet_test.in
Input Grid File: Data/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 002x001
tile Istr Iend Jstr Jend Npts
0 1 38 1 70 21280
1 39 75 1 70 20720
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 38.50 0.50 70.50 RHO-points
1 38.50 75.50 0.50 70.50 RHO-points
0 1.00 38.50 0.50 70.50 U-points
1 38.50 75.00 0.50 70.50 U-points
0 0.50 38.50 1.00 70.00 V-points
1 38.50 75.50 1.00 70.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 243
TileSide(1) = 75
TileSize(1) = 3300
Sediment Parameters, Grid: 01
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 03: bed_porosity
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
INLET_TEST Inlet Test Case
ANA_SEDIMENT Analytical sediment initial conditions.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NONLINEAR Nonlinear Model.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 6492) is active.
Node # 1 (pid= 6493) is active.
Fatal error in MPI_Send: Invalid datatype, error stack:
MPI_Send(173): MPI_Send(buf=0xbfe64e78, count=1, INVALID DATATYPE, dest=0, tag=2, MPI_COMM_WORLD) failed
MPI_Send(111): Null Datatype pointer
Error about inlet test cae
Re: Error about inlet test cae
I have succeed compiling it . My machine had mpich2 and openmpi before . And I uninstalled openmpi .
Then I compiled it again . Then I typed mpirun -np 4 ./oceanM coupling_inlet_test.in
It works well . It seems there is a conflict between mpich2 and openmpi .
But I still have a question about it .
If i type mpirun -np 4 ./oceanM coupling_inlet_test.in > & log &
The screen show -bash: syntax error near unexpected token `&'
But if I type mpirun -np 4 ./oceanM coupling_inlet_test.in ,it woks well .
Could you tell you why ?
It is because some of us are so stuck in our ways as to be using a Unix shell in the csh family. Job redirection is different between the sh family (including bash) and the other family. In this statement:
the first "&" sends the error output to the file log along with the standard output, while the second "&" puts the whole job into the background. The bash redirection is described here (search on "bash redirect stderr").
Thank you ! I have another question . i didn't succeed installing hdf5-1.8.6. So I installed netcdf4 without hdf5. And I didn't set NETCDF4 in build.bash(#export USE_NETCDF4=on).It seems works well in inlet test case. Then I want to couple roms with swan.Does it affect the result ?kate wrote:It is because some of us are so stuck in our ways as to be using a Unix shell in the csh family. Job redirection is different between the sh family (including bash) and the other family. In this statement:the first "&" sends the error output to the file log along with the standard output, while the second "&" puts the whole job into the background. The bash redirection is described here (search on "bash redirect stderr").Code: Select all
I can't say for SWAN, but the ROMS story is a little confusing. As it is now, USE_NETCDF4 means that the build system can count on the existence of nc-config (or perhaps it is sometimes nf-config). It can ask nc-config how to link things together, whether hdf is needed or not, whether -lnetcdff is needed or not, and so on. Therefore, you can USE_NETCDF4 even if your build didn't include HDF5.
Inside ROMS, there's a cppdefs of NETCDF4 - that one does need HDF5. It means to create NETCDF output in the new HDF5 format.
Thank you for your reply !kate wrote:I can't say for SWAN, but the ROMS story is a little confusing. As it is now, USE_NETCDF4 means that the build system can count on the existence of nc-config (or perhaps it is sometimes nf-config). It can ask nc-config how to link things together, whether hdf is needed or not, whether -lnetcdff is needed or not, and so on. Therefore, you can USE_NETCDF4 even if your build didn't include HDF5.
