Have Upwelling Test up and running in serial mode on Linux with gfortran. Created new directory in Projects folder, EstuarySedment, and copied into it: build.bash from successful upwelling run, estuary_test.h, ocean_estuary_test.in, sediment_estuary_test.in, and varinfo.dat. Then modified build script to:
Export ROMS_APPLICATIOIN=ESTUARY_TEST
Export MY_PROJECT_DIR${MY_ROOT_DIR)/Projects/EstuarySediment
Build appears to configure properly and creates: oceanS
I try to execute oceans with the command:
./oceans < ocean_estuary_test.in sediment_estuary_test.in > sedimentTest.out
Run quickly fails with sedimentTest.out as follows:
$HOME/ROMS/trunk/ROMS/External/varinfo.dat
Doesn’t seem to make any difference if I set the path in ocean_estuary_test.in to the ROMS External source directory or the copy of varinfo.dat in my project directory,
VARNAME = ROMS/External/varinfo.dat, OR VARNAME = varinfo.dat,
I get the same error.
Any recommendations to fix and any other obvious flaws with my set-up so far?
PROBLEMS RUNNING ESTUARY SEDIMENT TEST
Re: PROBLEMS RUNNING ESTUARY SEDIMENT TEST
I see a couple things that are either typos or mistakes.
The executable is oceanS (note uppercase S). The input file you should be piping to that is
ocean_estuary_test.in, not sediment_estuary_test.in (that file should be specified in ocean_estuary_test.in).
Unless you have reason to change it, best to leave varinfo.dat where it is, and in the .in file, use the full path name, e.g.:
VARNAME = /fullpathtoromssourcecode/ROMS/External/varinfo.dat
If that doesn't work, post your build.bash file and a ls of what you have in your project directory.
Chris Sherwood, USGS
1 508 457 2269
1 508 457 2269
Chris,
Sincerely appreciate the quick reply and assistance. The typos you identified oceans versus oceanS were errors in my posting versus my actual code. I reset the ocean_estuary_test.in pointer to varinfo.dat as follows:
VARNAME = ${HOME}/ROMS/trunk/ROMS/External/varinfo.dat
Then I re-ran: ./oceans < ocean_estuary_test.in > sedimentTest.out and got the same unable to open varinfo.dat error.
Below is the ls from my project directory (Projects/EstuarySediment):
Build
build.bash
oceanS
estuary_test.h
Note, I was unable to upload my build script—cycled “upload in progress” for over 30 minutes, so I stopped and tried again and finally gave up and copied txt below. thanks again for your assistance.
John
#!/bin/bash
# svn $Id: build.bash 585 2012-01-03 18:44:28Z arango $
# Copyright (c) 2002-2012 The ROMS/TOMS Group :::
# Licensed under a MIT/X style license :::
# See License_ROMS.txt :::
#::::::::::::::::::::::::::::::::::::::::::::::::::::: Hernan G. Arango :::
# ROMS/TOMS Compiling Script :::
# Script to compile an user application where the application-specific :::
# files are kept separate from the ROMS source code. :::
# Q: How/why does this script work? :::
# A: The ROMS makefile configures user-defined options with a set of :::
# flags such as ROMS_APPLICATION. Browse the makefile to see these. :::
# If an option in the makefile uses the syntax ?= in setting the :::
# default, this means that make will check whether an environment :::
# variable by that name is set in the shell that calls make. If so :::
# the environment variable value overrides the default (and the :::
# user need not maintain separate makefiles, or frequently edit :::
# the makefile, to run separate applications). :::
# Usage: :::
# ./build.bash [options] :::
# Options: :::
# -j [N] Compile in parallel using N CPUs :::
# omit argument for all available CPUs :::
# -noclean Do not clean already compiled objects :::
# Notice that sometimes the parallel compilation fail to find MPI :::
# include file "mpif.h". :::
parallel=0
clean=0
while [ $# -gt 0 ]
do
case "$1" in
-j )
shift
parallel=1
test=`echo $1 | grep -P '^\d+$'`
if [ "$test" != "" ]; then
NCPUS="-j $1"
shift
else
NCPUS="-j"
fi
-noclean )
shift
clean=0
echo ""
echo "$0 : Unknown option [ $1 ]"
echo ""
echo "Available Options:"
echo ""
echo "-j [N] Compile in parallel using N CPUs"
echo " omit argument for all avaliable CPUs"
echo "-noclean Do not clean already compiled objects"
echo ""
exit 1
esac
done
# Set the CPP option defining the particular application. This will
# determine the name of the ".h" header file with the application
# CPP definitions.
export ROMS_APPLICATION=ESTUARY_TEST
# Set a local environmental variable to define the path to the directories
# where all this project's files are kept.
export MY_ROOT_DIR=${HOME}/ROMS
export MY_PROJECT_DIR=${MY_ROOT_DIR}/Projects/EstuarySediment
# The path to the user's local current ROMS source code.
# If using svn locally, this would be the user's Working Copy Path (WCPATH).
# Note that one advantage of maintaining your source code locally with svn
# is that when working simultaneously on multiple machines (e.g. a local
# workstation, a local cluster and a remote supercomputer) you can checkout
# the latest release and always get an up-to-date customized source on each
# machine. This script is designed to more easily allow for differing paths
# to the code and inputs on differing machines.
#export MY_ROMS_SRC=${MY_ROOT_DIR}/branches/arango
export MY_ROMS_SRC=${MY_ROOT_DIR}/trunk
# ${MY_ROMS_SRC}/Compilers. If this is the case, the you need to keep
# these configurations files up-to-date.
export COMPILERS=${MY_ROMS_SRC}/Compilers
#export COMPILERS=${MY_ROOT_DIR}/Compilers
# Set tunable CPP options.
# Sometimes it is desirable to activate one or more CPP options to run
# different variants of the same application without modifying its header
# file. If this is the case, specify each options here using the -D syntax.
# Notice also that you need to use shell's quoting syntax to enclose the
# definition. Both single or double quotes work. For example,
#export MY_CPP_FLAGS="-DAVERAGES"
#export MY_CPP_FLAGS="${MY_CPP_FLAGS} -DDEBUGGING"
# can be used to write time-averaged fields. Notice that you can have as
# many definitions as you want by appending values.
#export MY_CPP_FLAGS="-D"
# Other user defined environmental variables. See the ROMS makefile for
# details on other options the user might want to set here. Be sure to
# leave the switches meant to be off set to an empty string or commented
# out. Any string value (including off) will evaluate to TRUE in
# conditional if-statements.
#export USE_MPI=on # distributed-memory parallelism
#export USE_MPIF90=on # compile with mpif90 script
#export which_MPI=mpich2 # compile with MPICH2 library
export which_MPI=openmpi # compile with OpenMPI library
#export USE_OpenMP=on # shared-memory parallelism
#export FORT=ifort
export FORT=gfortran
#export FORT=pgi
#export USE_DEBUG=on # use Fortran debugging flags
export USE_LARGE=on # activate 64-bit compilation
#export USE_NETCDF4=on # compile with NetCDF-4 library
#export USE_PARALLEL_IO=on # Parallel I/O with Netcdf-4/HDF5
#export USE_MY_LIBS=on # use my library paths below
# There are several MPI libraries available. Here, we set the desired
# "mpif90" script to use during compilation. This only works if the make
# configuration file (say, Linux-pgi.mk) in the "Compilers" directory
# has the following definition for FC (Fortran Compiler) in the USE_MPI
# section:
# FC := mpif90
# that is, "mpif90" defined without any path. Notice that the path
# where the MPI library is installed is computer dependent. Recall
# that you still need to use the appropriate "mpirun" to execute.
if [ -n "${USE_MPIF90:+1}" ]; then
case "$FORT" in
ifort )
if [ "${which_MPI}" = "mpich" ]; then
export PATH=/opt/intelsoft/mpich/bin:$PATH
elif [ "${which_MPI}" = "mpich2" ]; then
export PATH=/opt/intelsoft/mpich2/bin:$PATH
export PATH=/opt/intelsoft/openmpi/bin:$PATH
fi
pgi )
export PATH=/opt/pgisoft/mpich/bin:$PATH
export PATH=/opt/pgisoft/mpich2/bin:$PATH
export PATH=/opt/pgisoft/openmpi/bin:$PATH
fi
gfortran )
export PATH=/opt/gfortransoft/mpich2/bin:$PATH
export PATH=/opt/gfortransoft/openmpi/bin:$PATH
fi
esac
fi
# If the USE_MY_LIBS is activated above, the path of the libraries
# required by ROMS can be set here using environmental variables
# which take precedence to the values specified in the make macro
# definitions file (Compilers/*.mk). For most applications, only
# the location of the NetCDF library is needed during compilation.
#:wg
# Notice that when the USE_NETCDF4 macro is activated, we need the
# serial or parallel version of the NetCDF-4/HDF5 library. The
# configuration script NC_CONFIG (available since NetCDF 4.0.1)
# is used to set up all the required libraries according to the
# installed options (openDAP, netCDF4/HDF5 file format). The
# parallel library uses the MPI-I/O layer (usually available
# in MPICH2 and OpenMPI) requiring compiling with the selected
# MPI library.
# In ROMS distributed-memory applications, you may use either the
# parallel version is required when parallel I/O is activated
# (ROMS cpp option PARALLEL_IO and HDF5).
# However, in serial or shared-memory ROMS applications, we need
# to use the serial version of the NetCDF-4/HDF5 to avoid conflicts
# with the compiler. We cannot activate MPI constructs in serial
# or shared-memory ROMS code. Hybrid parallelism is not possible.
# Recall also that the MPI library comes in several flavors:
# MPICH, MPICH2, OpenMPI, etc.
case "$FORT" in
ifort )
export ESMF_OS=Linux
export ESMF_COMPILER=ifort
export ESMF_BOPT=O
export ESMF_ABI=64
export ESMF_COMM=mpich
export ESMF_SITE=default
export ARPACK_LIBDIR=/opt/intelsoft/serial/ARPACK
export ESMF_DIR=/opt/intelsoft/mpich/esmf
export MCT_INCDIR=/opt/intelsoft/mpich/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich/PARPACK
export ESMF_DIR=/opt/intelsoft/mpich2/esmf
export MCT_INCDIR=/opt/intelsoft/mpich2/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich2/PARPACK
export ESMF_DIR=/opt/intelsoft/openmpi/esmf
export MCT_INCDIR=/opt/intelsoft/openmpi/mct/include
export MCT_LIBDIR=/opt/intelsoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/openmpi/PARPACK
fi
fi
if [ -n "${USE_NETCDF4:+1}" ]; then
if [ -n "${USE_PARALLEL_IO:+1}" ] && [ -n "${USE_MPI:+1}" ]; then
export NC_CONFIG=/opt/intelsoft/mpich/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/mpich/netcdf4/include
export NC_CONFIG=/opt/intelsoft/mpich2/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/mpich2/netcdf4/include
export NC_CONFIG=/opt/intelsoft/openmpi/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/openmpi/netcdf4/include
fi
else
export NC_CONFIG=/opt/intelsoft/serial/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=${HOME}/netcdf/include
export NETCDF_LIBDIR=${HOME}/netcdf/lib
fi
pgi )
export ESMF_COMPILER=pgi
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=/opt/pgisoft/serial/ARPACK
export ESMF_DIR=/opt/pgisoft/mpich/esmf
export MCT_INCDIR=/opt/pgisoft/mpich/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich/PARPACK
export ESMF_DIR=/opt/pgisoft/mpich2/esmf
export MCT_INCDIR=/opt/pgisoft/mpich2/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich2/PARPACK
export ESMF_DIR=/opt/pgisoft/openmpi/esmf
export MCT_INCDIR=/opt/pgisoft/openmpi/mct/include
export MCT_LIBDIR=/opt/pgisoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/openmpi/PARPACK
fi
fi
export NC_CONFIG=/opt/pgisoft/mpich/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/pgisoft/mpich/netcdf4/include
export NC_CONFIG=/opt/pgisoft/mpich2/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/pgisoft/mpich2/netcdf4/include
export NC_CONFIG=/opt/pgisoft/openmpi/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/pgisoft/openmpi/netcdf4/include
fi
else
export NC_CONFIG=/opt/pgisoft/serial/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/pgisoft/serial/netcdf3/lib
fi
gfortran )
export ESMF_COMPILER=gfortran
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=/opt/gfortransoft/serial/ARPACK
export ESMF_DIR=/opt/gfortransoft/mpich2/esmf
export MCT_INCDIR=/opt/gfortransoft/mpich2/mct/include
export MCT_LIBDIR=/opt/gfortransoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/gfortransoft/mpich2/PARPACK
export ESMF_DIR=/opt/gfortransoft/openmpi/esmf
export MCT_INCDIR=/opt/gfortransoft/openmpi/mct/include
export MCT_LIBDIR=/opt/gfortransoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/gfortransoft/openmpi/PARPACK
fi
fi
export NC_CONFIG=/opt/gfortransoft/mpich2/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/gfortransoft/mpich2/netcdf4/include
export NC_CONFIG=/opt/gfortransoft/openmpi/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/gfortransoft/openmpi/netcdf4/include
fi
else
export NC_CONFIG=/opt/gfortransoft/serial/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/gfortransoft/serial/netcdf4/include
fi
else
fi
esac
fi
# The rest of this script sets the path to the users header file and
# analytical source files, if any. See the templates in User/Functionals.
# If applicable, use the MY_ANALYTICAL_DIR directory to place your
# customized biology model header file (like fennel.h, nemuro.h, ecosim.h,
# etc).
export MY_HEADER_DIR=${MY_PROJECT_DIR}
export MY_ANALYTICAL_DIR=${MY_PROJECT_DIR}
# Put the binary to execute in the following directory.
export BINDIR=${MY_PROJECT_DIR}
# Put the f90 files in a project specific Build directory to avoid conflict
# with other projects.
export SCRATCH_DIR=${MY_PROJECT_DIR}/Build
# Go to the users source directory to compile. The options set above will
# pick up the application-specific code from the appropriate place.
cd ${MY_ROMS_SRC}
# Remove build directory.
if [ $clean -eq 1 ]; then
make clean
fi
# Compile (the binary will go to BINDIR set above).
if [ $parallel -eq 1 ]; then
make $NCPUS
else
make
fi
Build
build.bash
oceanS
estuary_test.h
John
#!/bin/bash
# Usage: :::
# Options: :::
parallel=0
clean=0
while [ $# -gt 0 ]
do
case "$1" in
-j )
shift
parallel=1
NCPUS="-j $1"
shift
else
NCPUS="-j"
fi
-noclean )
shift
clean=0
echo ""
echo ""
echo ""
echo ""
exit 1
esac
done
# CPP definitions.
#export FORT=ifort
#export FORT=pgi
# section:
# FC := mpif90
case "$FORT" in
ifort )
fi
pgi )
fi
gfortran )
fi
esac
fi
#:wg
# MPI library.
case "$FORT" in
ifort )
export ESMF_BOPT=O
export ESMF_ABI=64
fi
fi
fi
else
fi
else
fi
pgi )
export ESMF_BOPT=O
export ESMF_ABI=64
fi
fi
fi
else
fi
else
fi
gfortran )
export ESMF_BOPT=O
export ESMF_ABI=64
fi
fi
fi
else
fi
else
fi
esac
fi
# etc).
cd ${MY_ROMS_SRC}
make clean
fi
make $NCPUS
else
make
fi
John,
I did an svn update (just to make sure we were working on the same code) and copied the build.bash, .in and .h files to a project dir, modified build.bash, and built the estuary test case.
Putting this in the .in file:
VARNAME = ${HOME}/src/my_roms/ROMS/External/varinfo.dat
does not work for me either. But if I replace ${HOME} with the actual path, it works fine. Check your syntax and make sure it is there from the project directory:
ls /home/csherwood/src/my_roms/ROMS/External/varinfo.dat
If any of your files have been on a Windows system, make sure they they have not gotten extra <CR><LF> added to the end.
1 508 457 2269
1 508 457 2269
Chris,
I use the Linux editor vim, so don't think I have introduced any unwanted <CR><LF> but this is good to know for future reference. Ran pwd for the ROMS/External directory and put in full path returned:
/afs/lions.odu.edu/home/j/jande023/ROMS/trunk/ROMS/External/varinfo.dat
also tried
~/ROMS/trunk/ROMS/External/varinfo.dat
Couldn't locate in either case, so I reverted back to the way I had successfully set up the Upwelling test case with:
VARNAME = varinfo.dat and varinfo.dat in my EstuarySediment project directory.
Now get a different error: At line 434 of file inp_par.f90 Fortran runtime error: No such file or directory. Not sure where inp_par.f90 is to investigate further. Next step is to svn relevant files; but, I fear that's not the issue. My output file, sedimentTest.out, is copied below, showing where the run terminates.
Tuesday - January 1, 2013 - 8:19:08 PM
Suspended Sediment Test in an Estuary
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 634M
Local Root : /afs/lions.odu.edu/home/j/jande023/ROMS/trunk
Header Dir : /afs/lions.odu.edu/home/j/jande023/ROMS/Projects/EstuarySediment
Header file : estuary_test.h
Analytical Dir: /afs/lions.odu.edu/home/j/jande023/ROMS/Projects/EstuarySediment
Resolution, Grid 01: 0200x0003x020, Parallel Threads: 1, Tiling: 001x001
28800 ntimes Number of timesteps for 3-D equations.
2880 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
into history file.
time-averaged data.
1440 nAVG Number of timesteps between the writing of
for tracer 02: salt
for turbulent energy.
5.0000E-03 Zob Bottom roughness (m).
5.0000E-03 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.000 Tcline S-coordinate surface/bottom layer width (m) used
1028.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
1.2500E-01 Tnudg(01) Nudging/relaxation time scale (days)
1.2500E-01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E-03 Znudg Nudging/relaxation time scale (days)
1.0000E-03 M2nudg Nudging/relaxation time scale (days)
1.0000E-03 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+00 obcfac Factor between passive and active
of State.
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Tile partition information for Grid 01: 0200x0003x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 200 1 3 12000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 201.50 0.50 3.50 RHO-points
0 0.00 201.00 0.50 3.50 U-points
0 0.50 201.50 0.00 3.00 V-points
also tried
SVN Revision : 634M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 200 1 3 12000
It is weird that putting the full path name in did not fix the problem.
The .f90 files are in the ./Build directory: they are made when the C pre-processor program is run on the .F files, and are a good place to look to see what code is actually included after all of the #ifdef commands are resolved.
Have you changed the path of the sediment_estuary_test.in file specified in your ocean_estuary_test.in file? It starts out as /ROMS/External, but you should remove the path prefix to that it points to the local version.
1 508 457 2269
1 508 457 2269
Good news Chris,
Had not specified location of sediment_estuary_test.in in ocean_estuary_test.in and doing so appearred to fix the problem. Did not change the path on the remaining files in the "External" folder as shown below:
APARNAM = ROMS/External/s4dvar.in
SPOSNAM = ROMS/External/stations.in
FPOSNAM = ROMS/External/floats.in
BPARNAM = ROMS/External/bio_Fennel.in
SPARNAM = sediment_estuary_test.in
USRNAME = ROMS/External/MyFile.dat
Run appears to complete "ROMS/TOMS: DONE... Wednesday - January 2, 2013 - 8:00 15 A
and created .nc files. Guess I need to plot to see if the run was actually successful?
