Hi.every one
I have a problem when I want to compile build bash script. after writing of ./build.bash command, the following message appear on my screen.
./build.bash: line 40: $'\r': command not found
./build.bash: line 43: $'\r': command not found
./build.bash: line 46: syntax error near unexpected token `$'in\r''
'/build.bash: line 46: ` case "$1" in
I appreciate you to help me
compiling of build.bash script file
Re: compiling of build.bash script file
This is listed in the FAQ at wikiroms, along with a solution. Another solution is to download within Cygwin if you plan to run within Cygwin.
